jQuery UI Widgets Forums Angular Component Load changes TreeGrid Style
This topic contains 2 replies, has 2 voices, and was last updated by  mattooren 8 years, 3 months ago.
  • Component Load changes TreeGrid Style #90359
    mattooren
    Hi all,
    I want to load a certain component based on a certain element being selected in a treegrid.
    However, when I load the component the style of my treegrid changes.
    To illustrate:
    TreeGrid before click:
    TreeGrid after click:
    TreeGrid afterclick
    CSS:
    CSS Before Click:
    CSS before click
    CSS After Click:
    CSS afterclick
    I use the following code to load the components:
    <projectDetailsComponent *ngIf=”loadComponentBoolean” (onReloadTree)=”onReloadTree()” [projectID]=”selectedID”></projectDetailsComponent>
    Does anyone know how I prevent the CSS from changing?
    Thanks in advance!
    Component Load changes TreeGrid Style #90414
    Hi mattooren,
    Selection style is applied when you select something in the TreeGrid. You can edit the CSS theme which you use if you wish a different behavior.
    Component Load changes TreeGrid Style #90566
    mattooren
    That should explain it!
    Kind regards,
    Matthijs
