jQuery UI Widgets Forums Grid Column width problems
This topic contains 4 replies, has 2 voices, and was last updated by  admin 6 months, 1 week ago.
  • Column width problems #135435
    ajcs
    I want the grid to take up the whole width of the page without horizontal scroll.
    If I set the column widths by percentage to add to 100% (e.g. Column widths 30% and 70%) the grid looks correct initially but I have the following two problems:
    1. If the grid gets more data and a vertical scrollbar appears then a horizontal scrollbar appears.
    2. If the browser window is resized the grid is therefore resized but the columns do not auto resize to stay with the percentages.
    How do I fix the problems above to compensate for the vertical scrollbar appearing and resize?
    Column width problems #135438
    admin
    Hi ajcs,
    You can look at this: https://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/autosize.htm?fluent
    Column width problems #135443
    ajcs
    The example you show is what I am doing. Is this something that was fixed recently? (maybe I need an update?)
    In addition if I want some fixed width columns and leave one column without a width it fills the rest of the space but it has the same problems above when resizing the grid and scrollbar. Should this also work correctly as with your example?
    Column width problems #135444
    ajcs
    I updated to the latest version and it has fixed the problem with column percentages and works correctly.
    It still has the same problems above if I want some fixed columns and leave one column with no width.
    So if I want columns mainly with percentages but want one column a fixed width (maybe it contains a button or something) is there a way to do that?
    Something like with divs when you can use calc(25% – 20px)?
    Column width problems #135446
    admin
    Hi ajcs,
    In this case, the sum of percentages should be less than 100%, have one column with fixed width and another one without width to take up what’s remaining.
