jQuery UI Widgets Forums Grid Column header menu width issue.
This topic contains 6 replies, has 2 voices, and was last updated by  Peter Stoev 12 years, 9 months ago.
  • Column header menu width issue. #6010
    xmon72206
    I am having an issue where the column header menu width is less than half the size it should be. It seems to be fixed when I group and ungroup a column. Do you know why this happens? I am definitely not changing the menu width. It happened once before when my source is an array. This time my source is coming from a remote function returning XML.
    Here is an image:
    Xmon22.
    Column header menu width issue. #6013
    Hi Xmon22,
    We will not be able to reproduce that issue with the provided details. Would you please provide additional details like:
    – jQuery version
    – jQWidgets version
    – Small Sample which reproduces the issue.
    Column header menu width issue. #6061
    xmon72206
    We are using:
    – jquery-1.7.2
    – jqwidgets-2.3.0
    I did some playing around and to recreate the problem you have create and bind the grid while the grid is hidden. Once you make the grid visible you should noticed that the header menus are not sized correctly.
    Xmon22.
    Column header menu width issue. #6062
    Hi Xmon22,
    I am still unable to reproduce the reported issue.
    Here’s my code:
    $("#jqxgrid").css('visibility', 'hidden');
    // initialize jqxGrid
    $("#jqxgrid").jqxGrid(
    width: 670,
    altrows: true,
    enabletooltips: true,
    { text: 'Product Name', datafield: 'ProductName', width: 250 },
    { text: 'Quantity per Unit', datafield: 'QuantityPerUnit', width: 150 },
    { text: 'Unit Price', datafield: 'UnitPrice', cellsalign: 'right', cellsformat: 'c2', width: 70 },
    { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', cellsrenderer: cellsrenderer, width: 100 },
    { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued', width: 100 }
    $("#jqxgrid").css('visibility', 'visible');
    Column header menu width issue. #6064
    xmon72206
    Sorry I should had been for specific. I used
    $(“#jqxgrid”).css(‘display’, ‘none’);
    instead of
    $(“#jqxgrid”).css(‘visibility’, ‘hidden’);
    plus, I used a button to make the grid appear.
    Xmon22.
    Column header menu width issue. #6065
    xmon72206
    Thanks for the help.
    Xmon22.
    Column header menu width issue. #6099
    Hi Xmon22,
    There are 2 options – initialize the Grid when its container DIV tag is visible ( best option ) or call the Grid’s ‘render’ method once the DIV tag is visible.
