jQuery UI Widgets Forums General Discussions Code Formatting Issue
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 8 years, 6 months ago.
  • Code Formatting Issue #87419
    walker1234
    Why does the following code doesn’t shows up in formatted manner even after applying clicking code option after selecting all code text?
    ` this.myDocument = function (data_) {
    var source = {
    localdata: data_,
    datafields: [{
    type: ‘string’
    type: ‘string’
    type: ‘int’
    type: ‘int’
    datatype: “array”
    loadComplete: function (records) {
    var html;
    var color = ‘#FF0000′;
    //Get data
    var records = dataAdapter.records;
    var length = records.length;
    console.log(“Checking Length: “+length);// Outputs 5
    for (var i = 0; i < length; i++) {
    console.log(“checking Concepts here: ” +records[i].concept_text);
    html = “<div style=’margin: 10px;’><pre>” + records[1].doc_content + “</pre></div>”;
    html = html.replace(new RegExp(records[i].concept_text, ‘ig’), ‘<span style=”color:’ + color + ‘;”>’ + records[i].concept_text + ‘</span>’);
    console.log(“How many span tags you are noticing here?: ” + html);
    $(“#docContentPanel”).html(html);
    loadError: function (xhr, status, error) { },
    // perform data binding
    dataAdapter.dataBind();
    $(“#myPanel”).jqxGrid({
    width: ’122′,
    height: ’170′,
    columns: [{
    text: ‘Concept(s)’,
    datafield: ‘concept_text’,
    cellsalign: ‘center’,
    width: 100
    text: ‘Note Content’,
    datafield: ‘doc_content’,
    hidden: true
    var panel = $(“#docContentPanel”);
    var content = panel.html();
    panel.jqxPanel({
    width: ’750′,
    height: ’500′,
    scrollBarSize: 20
    $(“#myPanel”).on(‘cellclick’, function (event) {
    var value = event.args.value;
    // Use a regular expression to account for the beginning/end of the
    // input, arbitrary whitespace (including line feeds) as well as
    // adjacent tags
    var regExp = new RegExp(‘(^|>|\\s)(‘ + value + ‘)($|<|\\s)’, ‘g’);
    var scrollTop;
    var highlighted = content.replace(
    regExp,
    ‘$1<span class=”highlighted”>$2</span>$3′
    console.log (“Check for highlighted in click handler:” +highlighted);
    panel.jqxPanel(‘clearcontent’);
    panel.jqxPanel(‘append’, highlighted);
    // Get the offset of the last highlighted word relative
    // to the panel parent
    scrollTop = $(‘.highlighted:last’, panel).position().top;
    // Use the jqxPanel API to scroll to that word
    panel.jqxPanel(‘scrollTo’, 0, scrollTop);
    };// End of myDocument function
    Code Formatting Issue #87430
    Hello walker1234,
    Please select all your code and press the code button in the toolbar once. Make sure there are no extra grave accent signs so that the formatting is not broken.
    this.myDocument = function(data_) {
        var source = {
            localdata: data_,
            datafields: [{
                type: 'string'
                type: 'string'
                type: 'int'
                type: 'int'
            datatype: "array"
            loadComplete: function(records) {
                var html;
                var color = '#FF0000';
                //Get data
                console.log("Checking Length: " + length); // Outputs 5
                    console.log("checking Concepts here: " + records[i].concept_text);
                html = "<div style='margin: 10px;'><pre>" + records[1].doc_content + "</pre></div>";
                    html = html.replace(new RegExp(records[i].concept_text, 'ig'), '<span style="color:' + color + ';">' + records[i].concept_text + '</span>');
                console.log("How many span tags you are noticing here?: " + html);
                $("#docContentPanel").html(html);
            loadError: function(xhr, status, error) {},
            beforeLoadComplete: function(records) {}
        $("#myPanel").jqxGrid({
            width: '122',
            height: '170',
            columns: [{
                text: 'Concept(s)',
                datafield: 'concept_text',
                cellsalign: 'center',
                width: 100
                text: 'Note Content',
                datafield: 'doc_content',
                hidden: true
        var panel = $("#docContentPanel");
        panel.jqxPanel({
            width: '750',
            height: '500',
            scrollBarSize: 20
        $("#myPanel").on('cellclick', function(event) {
            // adjacent tags
            var regExp = new RegExp('(^|>|\\s)(' + value + ')($|<|\\s)', 'g');
            var scrollTop;
                regExp,
                '$1<span class="highlighted">$2</span>$3'
            console.log("Check for highlighted in click handler:" + highlighted);
            panel.jqxPanel('clearcontent');
            panel.jqxPanel('append', highlighted);
            scrollTop = $('.highlighted:last', panel).position().top;
            panel.jqxPanel('scrollTo', 0, scrollTop);
    }; // End of myDocument function
