jQuery UI Widgets Forums Grid clear and reset column
This topic contains 3 replies, has 4 voices, and was last updated by  OlgaKorneeva 3 years, 3 months ago.
  • clear and reset column #54987
    jahnvi25
    i have editable cell. what is the best way to clear value of all cells to default /. i am using following method
    var rows = $(‘#table’).jqxGrid(‘getrows’);
    $(‘#table’).jqxGrid(‘beginupdate’);
    for(var i=0;i<rows.length;i++){
    rows[i].callQty = null;
    rows[i].putQty = null;
    //also reset the blue color
    rows[i].hasQty = ‘no’;
    $(‘#table’).jqxGrid(‘endupdate’);
    is there any other better solution ?
    clear and reset column #54997
    Hello jahnvi25,
    There is no built-in method for this functionality, because the “default” values are user-specific. Your approach is suitable and there should be no issues with it. Another idea is to load the grid with the default values, if possible.
    clear and reset column #121385
    princegajjar
    Hello, I want to restore my particular column from several columns whenever I click the different cells of that column. So Is it possible in jqxgrid to restore the previous cell for only a single column?
    clear and reset column #121387
    OlgaKorneeva
