jQuery UI Widgets Forums Editors CheckBox, RadioButton CheckBox Disable/Enable Issue
This topic contains 3 replies, has 2 voices, and was last updated by  ivailo 8 years, 4 months ago.
  • CheckBox Disable/Enable Issue #89739
    kdisarno
    Peter, et al…
    I can’t for the life of me figure out why my checkbox is not enabling. After going through a thousand lines of JS, I created a fiddle to eliminate everything I’ve written and see if it works. To my surprise, it doesn’t!
    Can you point me in the right direction?
    JSFiddle
    Thanks!
    EDIT: Running v4.3.0
    CheckBox Disable/Enable Issue #89747
    ivailo
    Hi kdisarno,
    The problem in your demo is the usage of a wrong selector.
    Please change $("jqxButton").on('click', function() to $("#jqxButton").on('click', function() an the code will work as expected.
    Ivailo Ivanov
    CheckBox Disable/Enable Issue #89751
    kdisarno
    Ivailo, that was my bad. You’re correct.
    I guess I’ll go through everything on my end again. The selector is obviously not my issue: I’d be getting console errors, and the text is turning from gray to black when I do my enable (so I know something is working). For some reason the dang box part of the checkbox refuses to enable.
    CheckBox Disable/Enable Issue #89761
    ivailo
    Hi kdisarno,
    Please, refer to this demo. It can be helpful for you.
    Ivailo Ivanov
