jQuery UI Widgets Forums Chart Chart legend not clickable
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 10 years, 2 months ago.
  • Chart legend not clickable #67241
    JulienR31
    I have implemented a jqxchart which was working correctly with the version 3.5.0 of jqwidget.
    But after integrating the 3.7.0 version, i encoutered some problems with the jqxchart component :
    – the stackedcolumn chart render empty bar column (they was filled before the version upgrade)
    – on firefox 28, the legend is not clickable (it is not possible to select/deselect an element in the legend)
    Any idea ?
    Julien
    Chart legend not clickable #67243
    Hello Julien,
    Please note that there have been some changes in the API of jqxChart in the latest version. Make sure you update your code in accordance with them. If the issue persists, please provide us with a JSFiddle example which demonstrates it.
