jQuery UI Widgets Forums Grid cellvaluechanged does not fire if I click on button outside grid
This topic contains 1 reply, has 1 voice, and was last updated by  grandehombre 10 years, 12 months ago.
  • grandehombre
    I have an event handler set up to handle ‘cellvaluechanged’.
    If I edit the contents of a column and press TAB or click anywhere else in the grid, the event fires correctly.
    However, if I click on a button (which saves grid data etc) that is outside the grid, this event does not fire.
    $(dataTable).on('cellvaluechanged', function (event)
    	var args = event.args;
    	//var column = args.datafield;
    	var row = args.rowindex;
    	//var value = args.newvalue;
    	//var oldvalue = args.oldvalue;
    	var data = $(dataTable).jqxGrid('getrowdata', row);
    Any suggestions would be welcome!
    Cheers,
    Nick
    ps: I am using ‘jQWidgets v3.2.2 (2014-Mar-21)’
    grandehombre
    [admin, please delete this thread.]
    I have changed the sequence that I use to place the grid in edit/viewOnly mode (whereby the grid becomes editable if the screen is in add/edit mode and some columns of the grid become editable depending on contents of other columns).
    It now works and I don’t know why.
    I don’t want to create confusion or take up the developers’ time, so please delete this entire thread.
    Cheers,
    Nick
