jQuery UI Widgets Forums Grid Cells Rendering within a loop
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 2 months ago.
  • Cells Rendering within a loop #50004
    zbrady
    I am trying to apply a unique cellsrenderer to each column via a loop. However, the j in rowData.Line[j] does not hold the value. Is there a way to pass the value of j to the cellsrenderer function?
    for(var j = 0; j < columnArray.length; j++){
                var cellsrenderer = function (indexRow, column, cellValue, defaultHtml, colSettings, rowData) {
                    return '<div style="text-align: center; margin-top: 5px;">' + rowData.Line[j] + '</div>';
                $('#jqxgrid').jqxGrid('setcolumnproperty', columnArray[j] ,'cellsrenderer', cellsrenderer);
    Cells Rendering within a loop #50005
    Hi zbrady,
    “setcolumnproperty” expects a datafield as first parameter. The cellsrenderer definition according to me is incorrect to. The method should depend only on the parameters which the Grid passes to it.
    Cells Rendering within a loop #50007
    zbrady
    I don’t think I asked my question correctly..
    This code works, if I hard code the zero into rowData.Line instead of putting j. However, I am looking for a way to pass in j to rowData.Line .
             return '<div style="text-align: center; margin-top: 5px; ">' + rowData.Line[0] '</div>';
    Cells Rendering within a loop #50009
    Hi zbrady,
    That’s what I meant. You can’t pass custom variables to a function called internally by jqxGrid.
