jQuery UI Widgets › Forums › Grid › Cell Alignment plus offset?
Tagged: align, Cell, cellsalign, cellsformat, cellsrenderer, column, currency, grid, jqxgrid, margin
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 10 years, 10 months ago.
I want my currency column to be right aligned but with a little margin between the last digit and the column line to the right. This is because it is right justified immediately next to a left justified column to it’s right and it looks bad.
I have a table were some values are centered, some left justified and currency needs to be aligned along the decimal points.
Hello jonfrain,
You can achieve this by using cellsrenderer. Here is an example, based on the demo Default Functionality. Note that if you use cellsrenderer, the cellsformat is disregarded and you would have to manually append “$”, as shown.
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdata.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxmenu.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdropdownlist.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.sort.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.pager.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.selection.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxgrid.edit.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript"> $(document).ready(function () { var url = "../sampledata/products.xml"; // prepare the data var source = { datatype: "xml", datafields: [ { name: 'ProductName', type: 'string' }, { name: 'QuantityPerUnit', type: 'int' }, { name: 'UnitPrice', type: 'float' }, { name: 'UnitsInStock', type: 'float' }, { name: 'Discontinued', type: 'bool' } ], root: "Products", record: "Product", id: 'ProductID', url: url }; var cellsrenderer = function (row, columnfield, value, defaulthtml, columnproperties, rowdata) { return '<span style="margin: 4px; margin-right: 10px; float: ' + columnproperties.cellsalign + ';">$' + value.toFixed(2) + '</span>'; } var dataAdapter = new $.jqx.dataAdapter(source, { downloadComplete: function (data, status, xhr) { }, loadComplete: function (data) { }, loadError: function (xhr, status, error) { } }); // initialize jqxGrid $("#jqxgrid").jqxGrid( { width: 850, source: dataAdapter, pageable: true, autoheight: true, sortable: true, altrows: true, enabletooltips: true, editable: true, selectionmode: 'multiplecellsadvanced', columns: [ { text: 'Product Name', columngroup: 'ProductDetails', datafield: 'ProductName', width: 250 }, { text: 'Quantity per Unit', columngroup: 'ProductDetails', datafield: 'QuantityPerUnit', cellsalign: 'right', align: 'right', width: 200 }, { text: 'Unit Price', columngroup: 'ProductDetails', datafield: 'UnitPrice', align: 'right', cellsalign: 'right', width: 200, cellsrenderer: cellsrenderer }, { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', width: 100 }, { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued' } ], columngroups: [ { text: 'Product Details', align: 'center', name: 'ProductDetails' } ] }); }); </script> </head> <body class='default'> <div id='jqxWidget' style="font-size: 13px; font-family: Verdana; float: left;"> <div id="jqxgrid"> </div> </div> </body> </html>
