jQuery UI Widgets › Forums › General Discussions › Can Knockout model be used with grid and input
This topic contains 3 replies, has 2 voices, and was last updated by rkamarowski 8 years, 1 month ago.
I have a Knockout model that is working with a grid. Can this same model be used for separate input widgets that use the same table?
I want the user to select an entry from the grid, and then edit that data in a separate form.`var GridModel = function ()
this.items = ko.observableArray();
var me = this;
$.ajax(
datatype: ‘json’,
url: “/php/eesVehiclesData.php”
}).done(function (data)
var jsonData = $.parseJSON(data);
me.items(jsonData);
};/* vehicles grid */
/* eesVehiclesModel(‘vehicles’);*/var modelGrid = new GridModel(
});var source =
datafields:
{name: “VehicleID”, type: “number”},
{name: “VehicleName”, type: “string”},
{name: “Active”, type: “boolean”},
{name: “Notes”, type: “string”},
{name: “VehicleTypeID”, type:”string”},
{name: “Year”, type: “string”},
{name: “VehicleMakeID”, type: “number”},
{name: “VehicleMake”, type: “string”},
{name: “Model”, type: “string”},
{name: “PurchaseDate”, type: “string”},
{name: “PurchasePrice”, type: “number”},
{name: “Miles”, type: “number”},
{name: “Hours”, type: “number”},
{name: “UserID”, type: “number”},
{name: “User”, type: “string”}
localData: modelGrid.items,
async: false
};var dataAdapterVehicle = new $.jqx.dataAdapter(source,
loadError: function (xhr, status, error)
console.warn(xhr.responseText);
alert(error);
loadComplete: function ()
var length = dataAdapterVehicle.records.length;
var text = dataAdapterVehicle.records;
/*alert(text); */
});$(“#divGridLeftVehicle”).jqxGrid(
selectionmode: ‘singlerow’,
source: dataAdapterVehicle,
width: ‘100%’,
{ text: ‘Name’, datafield: ‘VehicleName’, width: ‘24%’ },
{ text: ‘Active’, datafield: ‘Active’, width: ‘8%’},
{ text: ‘Vehicle Type’, datafield: ‘VehicleTypeID’, width: ‘20%’},
{ text: ‘Make’, datafield: ‘VehicleMake’, width: ‘20%’},
{ text: ‘Model’, datafield: ‘Model’, width: ‘20%’},
{ text: ‘Year’, datafield: ‘Year’, width: ‘8%’}
$(“#divGridLeftVehicle”).bind(‘rowselect’, function (event)
var selectedRowIndex = event.args.rowindex;
var data = $(‘#divGridLeftVehicle’).jqxGrid(‘getrowdata’, selectedRowIndex);
$(“#h2RightHeader”).html(“Vehicle: <u>” + data.VehicleName + “</u>”);
$(‘#divRightTabs’).jqxTabs(‘enableAt’, 0);
$(‘#divRightTabs’).jqxTabs(‘select’, 0);
ko.applyBindings(modelGrid);
`Hello rkamarowski,
Yes, it is possible. Unfortunately, we do not have such example with the KnockoutJS, but you could try to create it.
I would like to suggest you look at this “Integration with jqxGrid” demo (as the approach).Best Regards,
Hristo HristovjQWidgets team
http://www.jqwidgets.comThank you.
Is anyone else doing this?
