jQuery UI Widgets › Forums › Editors › Button, RepeatButton, ToggleButton, LinkButton › Buttons with images disabled
Tagged: Angular button, Button, button with image, click event, disabled, disabled button, jQuery Button, jqxButton
This topic contains 5 replies, has 2 voices, and was last updated by pepe 8 years, 1 month ago.
Goodnight.
Buttons with images disabled ignore the click event . It is right?<!DOCTYPE html>
<html lang=”en”>
<title>jQuery Button Sample1</title>
<meta name=”keywords” content=”jQuery, Button, Toggle Button, Repeat Button, Link Button, Help Documentation” />
<body class=’default’>
<div id=’content’>
$(document).ready(function () {$(“#jqxButton”).jqxButton({
width: ‘100’,
height: ’50’,
disabled: true,
imgSrc: ‘../../images/andrew.png’
imgWidth: 25,
imgHeight: 25,});
$(“#jqxButton”).on(‘click’, function () {
alert(‘Button Clicked’);
</script><div style=’width: 150px;’ id=’jqxWidget’>
<div>
<input type=”button” id=’jqxButton’ />
</html>Hello pepe,
Your code’s syntax is incorrect – you are missing a comma after
imgSrc: '../../images/andrew.png'
. Aside from that, if a button is disabled, its click event should not be triggered. However, currently the event will be fired if the button image is clicked. We have created a work item for this issue and will try to fix it in a future version of jQWidgets.Best Regards,
http://www.jqwidgets.com/Dimitar thank you very much .
a greetingFor when the solution to this problem?
a greetingHello pepe,
Unfortunately, this issue has not yet been resolved and we cannot provide you with an ETA of the fix for it. We are sorry for the inconvenience.
http://www.jqwidgets.com/VERY WELL, THANKS
