jQuery UI Widgets Forums React Build error when I add jqxWindow control
This topic contains 3 replies, has 2 voices, and was last updated by  svetoslav_borislavov 1 year, 7 months ago.
  • Build error when I add jqxWindow control #133634
    nepalmer
    I’m trying to test using the jqxWindow control. I pulled the sample code from your site and I’m trying add that code to one of my test projects. When I add the new code in and try and compile I get this error:
    Compiled with problems:
    ERROR in ./node_modules/jqwidgets-scripts/jqwidgets-react-tsx/jqxwindow/react_jqxwindow.esm.js
    Module build failed (from ./node_modules/babel-loader/lib/index.js):
    SyntaxError: C:\Development\reponew\app\node_modules\jqwidgets-scripts\jqwidgets-react-tsx\jqxwindow\react_jqxwindow.esm.js: Identifier ‘jqxcore’ has already been declared. (4:12)
    2 | import * as jqxbuttons from ‘../../jqwidgets/jqxbuttons’;
    3 | import * as jqxwindow from ‘../../jqwidgets/jqxwindow’;
    > 4 | import * as jqxcore from ‘../../jqwidgets/jqxcore’;
    5 | import * as jqxbuttons from ‘../../jqwidgets/jqxbuttons’;
    6 | import * as jqxwindow from ‘../../jqwidgets/jqxwindow’;
    7 | import * as jqxcore from ‘../../jqwidgets/jqxcore’;
    My imports look like this
    import ‘jqwidgets-scripts/jqwidgets/styles/jqx.office.css’;
    import JqxButton, { IButtonProps } from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxbuttons’;
    import JqxButtonGroup, { IButtonGroupProps } from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxbuttongroup’;
    import JqxSplitter, { ISplitterProps } from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxsplitter’;
    import JqxTree, { ITreeProps, jqx } from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxtree’;
    import JqxComboBox, { IComboBoxProps } from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxcombobox’;
    import JqxCheckBox, { ICheckBoxProps } from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxcheckbox’;
    import JqxDropDownList, { IDropDownListProps } from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxdropdownlist’;
    import JqxNotification, { INotificationProps } from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxnotification’;
    import JqxTooltip from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxtooltip’;
    import JqxNumberInput from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxnumberinput’;
    import JqxInput, { IInputProps } from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxinput’;
    import { SearchBox, ISearchBoxStyles, ISearchBoxProps } from ‘@fluentui/react/lib/SearchBox’;
    import JqxListBox from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxlistbox’;
    import JqxWindow from ‘jqwidgets-scripts/jqwidgets-react-tsx/jqxwindow’;
    I’ve tried moving the jqxWindow window import around but nothing short of remving the jqxWindow code makes the project compile.
    Can you help me figrue this out?
    Thanks in advance
    Build error when I add jqxWindow control #133635
    Can you share your component here, please?
    Also, may you update to the latest version?
    The following component compiles and works:
    import * as React from “react”;
    import “jqwidgets-scripts/jqwidgets/styles/jqx.office.css”;
    import JqxButton, {
    IButtonProps,
    } from “jqwidgets-scripts/jqwidgets-react-tsx/jqxbuttons”;
    IButtonGroupProps,
    } from “jqwidgets-scripts/jqwidgets-react-tsx/jqxbuttongroup”;
    ISplitterProps,
    } from “jqwidgets-scripts/jqwidgets-react-tsx/jqxsplitter”;
    import JqxTree, {
    ITreeProps,
    jqx,
    } from “jqwidgets-scripts/jqwidgets-react-tsx/jqxtree”;
    IComboBoxProps,
    } from “jqwidgets-scripts/jqwidgets-react-tsx/jqxcombobox”;
    ICheckBoxProps,
    } from “jqwidgets-scripts/jqwidgets-react-tsx/jqxcheckbox”;
    IDropDownListProps,
    } from “jqwidgets-scripts/jqwidgets-react-tsx/jqxdropdownlist”;
    INotificationProps,
    } from “jqwidgets-scripts/jqwidgets-react-tsx/jqxnotification”;
    import JqxTooltip from “jqwidgets-scripts/jqwidgets-react-tsx/jqxtooltip”;
    import JqxNumberInput from “jqwidgets-scripts/jqwidgets-react-tsx/jqxnumberinput”;
    import JqxInput, {
    IInputProps,
    } from “jqwidgets-scripts/jqwidgets-react-tsx/jqxinput”;
    import JqxListBox from “jqwidgets-scripts/jqwidgets-react-tsx/jqxlistbox”;
    import JqxWindow from “jqwidgets-scripts/jqwidgets-react-tsx/jqxwindow”;
    const App = () => {
    const myWindow = React.createRef<JqxWindow>();
    return (
    {/* @ts-ignore */}
    <JqxWindow
    ref={myWindow}
    width={500}
    height={300}
    minWidth={200}
    maxWidth={700}
    minHeight={200}
    maxHeight={400}
    showCollapseButton={true}
    <div>Hi</div>
    </JqxWindow>
    export default App;
    Svetoslav Borislavov
    https://www.jqwidgets.com/
    Build error when I add jqxWindow control #133641
    nepalmer
    I checked the version I was running and I got this
    +– jqwidgets-scripts@15.0.0
    So I updated to version 17.0 and after doing that the error went away.
    Thanks for your help
    Build error when I add jqxWindow control #133645
    Thank you for the update!
    If you have any questions, do not hesitate to contact us!
