jQuery UI Widgets Forums Grid Bug with Paging on Mobile Devices
This topic contains 2 replies, has 2 voices, and was last updated by  Todor 6 years ago.
  • Bug with Paging on Mobile Devices #104683
    gawyndragonspawn
    Greetings,
    I just found what I think is a bug with paging on mobile devices or smaller screens. This is viewable on your own paging example
    To replicate, view this page on a mobile device, or in Chrome’s responsive development mode. Change the paging to 20 rows, scroll to the bottom of the page, and then click the paging size box again. You’ll see the selection box appears very far below the grid.
    The problem gets exponentially worse the longer the page is; for instance with 100 records loaded. Can you suggested a workaround, or estimated timeline for a fix?
    Dan
    Bug with Paging on Mobile Devices #104731
    Todor
    Hello Dan,
    Thank you for the feedback. We will create a work item about this behavior.
    Todor
    https://www.jqwidgets.com
    Bug with Paging on Mobile Devices #104732
    Todor
    Hello Dan,
    Also this would be fix in the next week or two.
    Todor
