jQuery UI Widgets Forums TreeGrid [BUG] aggregate row style problem
This topic contains 1 reply, has 2 voices, and was last updated by  Stanislav 7 years, 3 months ago.
  • [BUG] aggregate row style problem #98531
    liefdiy
    when I set “showAggregates = true”, the last row of aggregates has some problem, like the picture:
    bug
    [BUG] aggregate row style problem #98534
    Stanislav
    Hello liefdiy,
    The picture isn’t showing for some reason, sorry.
    Maybe you can re-send it or send us an example of some kind for us to examine the issue?
    When I test the demos on our website and the examples in the API there seem to be no problem and they work correctly, maybe you are setting a property that is breaking the widget? Take a look at your code an see if you can find the problem.
    Stanislav
