jQuery UI Widgets Forums Dialogs and Notifications Window Bootstrap form-group class not 100% inside jqxWindow
This topic contains 1 reply, has 2 voices, and was last updated by  Stanislav 7 years, 4 months ago.
  • Justintkw
    Hi:
    I have a jqxWindow on my page, with the following codes (bootstrap them is properly linked; removing the theme makes no difference):
    $(“#jqxWin_EditAd”).jqxWindow({ height: 525, width: 535, theme: ‘bootstrap’, isModal: true, resizable: false, autoOpen: false });
    The control looks like this:
    <div id="jqxWin_EditAd">
        <!--Frame for the window content-->
        <div id="jqxWin_EditAd_Title">
            Editing
        <div id="jqxWin_EditAd_Content">
            <div class="form-group">
                <label class="control-label">Main Title:</label>
                <input type="text" id="EditAd_MainTitle" name="EditAd_MainTitle" maxlength="100" class="form-control">
                <label class="control-label">Sub Title:</label>
                <input type="text" id="EditAd_SubTitle" name="EditAd_SubTitle" maxlength="100" class="form-control">
                <label class="control-label">Content:</label>
                <textarea id="EditAd_Content" name="EditAd_Content" row="5" maxlength="500" class="form-control" ></textarea>
        </div> <!--end jqxWindowContent-->
    </div> <!--end jqxWindow-->
    in the standard bootstrap.css, which I use, form-group has width of 100%. Yet when the window is opened, the text boxes and the text area stretched only half the width of the windows. Fearing that it might be the bootstrap css file, I replaced the class for each of the textbox/textarea with style=”width : 100%” instead. Still, the controls only extends to half the length of the window.
    Any suggestion on how to resolve this issue is greatly appreciated!
    Justin
    Stanislav
    Hello Justin,
    You can individually set the width of the elements using bootstrap.
    Stanislav
