jQuery UI Widgets Forums Grid ASP Classic and updaterow
This topic contains 9 replies, has 3 voices, and was last updated by  sergio57 8 years, 6 months ago.
  • ASP Classic and updaterow #77916
    RedantJ
    I feel like I’m close. What I want to do is POST to a new page, so that I can do a server SQL request:
    In my main page:
    						dataType: 'json',
    						url: "update.asp",
    						data: newdata,
    						type: "POST",
                        commit(true);
    In my update.asp page:
    <%dim strbarCode, strID
    strID = Request("ID")
    strbarCode = Request("barCode")
    sql =  "UPDATE tblHoldingBin SET Bar_Code = " & strbarCode & " WHERE OrderID = " & strID
    set rs = conn.Execute(sql)%>
    Any ideas how I can make this work?
    ASP Classic and updaterow #77982
    Hello RedantJ,
    Unfortunately, we do not have any examples of integration between jQWidgets and ASP Classic. This does not mean they cannot be integrated, though.
    ASP Classic and updaterow #78128
    RedantJ
    I’m thinking about a workaround of this problem using POST. If I’m able to POST the data that I need to update.asp, then it would just be a matter of requesting the data and I can continue onwards. I didn’t have any time this week to try it out this week on account of other priorities. I’ll post up when I succeed.
    ASP Classic and updaterow #78214
    RedantJ
    Update: The Ajax POST method does work and will require some tinkering. I am dealing with an issue that is Microsoft Access / IIS related at the moment.
    ASP Classic and updaterow #78314
    RedantJ
    After dealing with priorities, I’m back at work on this project.
    The IIS issue has been resolved. I’m still perfecting the code, the following works pretty good:
    Main page:
    						type:"POST",
    						url: "update.asp",
    						data: newdata,
    							success : function(d) {
    			                    commit(true);
    								alert("updated!");
    ….and on Update.asp:
    <%dim conn, strFoo1, strFoo2
    Set conn = Server.CreateObject("ADODB.Connection")
    conn.Mode = 3
    strFoo1 = Request.Form("Foo1")
    strFoo2 = Request.Form("Foo2")
    Conn.open "PROVIDER = MICROSOFT.JET.OLEDB.4.0;DATA SOURCE = C:\inetpub\wwwroot\HoldingBin\InvntryData.mdb"
    sql = "INSERT INTO tblTable (Foo1, Foo2) "
    sql = sql + "VALUES ('" & strFoo1 & "','" & strFoo2 & "')"
    conn.Execute(sql)
    conn.close
    There is still a lot of tinkering to do. The ajax passes on the data to update.asp the way I expected it to do, the SQL statement needs work, and I’m pretty sure I will need to add an index column for this to work right. I’m a few steps closer to where I need to be.
    Thanks guys!
    ASP Classic and updaterow #78318
    RedantJ
    It looks like what I will need to implement for ASP Classic will be similar to this. I will work on it for the rest of the week.
    (The wheels are turning, however slowly)
    ASP Classic and updaterow #78349
    RedantJ
    And that’s done:
    When generating a blank row:
    	var generaterow = function (i) {
            var row = {};
    	row["idxUID"] = i;
    	row["foo1"] = "";
            row["foo2"] = "";
            return row;
    and here:
                // create new row.
                $("#addrowbutton").bind('click', function () {
                    var datarow = generaterow(rowscount + 1);
    		var commit = $("#jqxgrid").jqxGrid('addrow', null, datarow);
    …when using it inside of a function, for example addrow:
    	var data = "action=insert&" + $.param(rowdata);
    		type: "GET",
    		url: "controller.asp",
    		data: data,
    			commit(true);
    			alert("added!");
    This generates:
    http://localhost/blah/controller.asp?action=insert&idxUID=41&foo1=&foo2=
    Which makes controller.asp:
    <%dim conn, strIndex
    strIndex = Request.QueryString("idxUID")
    strAction = Request.QueryString("action")
    Conn.open "PROVIDER = MICROSOFT.JET.OLEDB.4.0;DATA SOURCE = C:\blah\FooData.mdb"
    intComp = StrComp(strAction, "insert", vbTextCompare)
    if (intComp = 0) then
    	sql = "INSERT INTO tblTable (index) "
    	sql = sql + "VALUES (" & strIndex & ")"
    	conn.Execute(sql)
    end if
    conn.close
    So now it works!
    ASP Classic and updaterow #78360
    Hi RedantJ,
    Thank you for your contribution to the forum.
    ASP Classic and updaterow #78390
    RedantJ
    One more thing:
    As far as security goes, using GET in your ajax isn’t secure. I would use GET for testing purposes (to be sure the data is going from your grid to your controller). For a more secure page, use POST:
    (this is addrow)
    			type: "POST",
    			data: data,
    			success : function(data, status, xhr)
    		                commit(true);
    			        error: function(jqXHR, textStatus, errorThrown)
    				commit(false);
    and in controller:
    strIndex = Request.Form("idxUID")
    strAction = Request.Form("action")
    And now it’s more secure.
    ASP Classic and updaterow #88098
    sergio57
    RedantJ,
    I’m interested to integrate jqxgrid with classic asp, and I wanted to ask you if it was possible to have the scripts that you mention here, (update, delete, insert in the database with asp classic) in order to study them.
    If you think it’s possbile to do this I thank you in advance
    Good day and greetings
