jQuery UI Widgets Forums Grid Applying Custom Filtering With remote data leaves empty rows in grid
This topic contains 3 replies, has 2 voices, and was last updated by  Hristo 7 years, 7 months ago.
  • Exlord
            var columns = @Html.Raw(ViewBag.columns);
            var datafields= @Html.Raw(ViewBag.dataFields);
            var url = '@ViewBag.url';
            var lastGridUrl = url;
            var source;
            var gridOptions;
            var dataadapter;
            var _grid;
            var dateFrom;
            var dateFromHidden;
            var dateTo;
            var dateToHidden;
            var removeFilterBtn;
            var exportForm;
      source = {
        datafields: datafields,
        url: url,
        filter: function () {
          _grid.jqxGrid('updatebounddata', 'filter');
        sort: function () {
          _grid.jqxGrid('updatebounddata', 'sort');
        root: 'Rows',
          source.totalrecords = data.TotalRows;
      gridOptions = {
        virtualmode: true,
        width: '100%',
        showfilterrow: true,
        rtl: true,
        autoshowfiltericon: true,
        selectionmode: 'checkbox',
          return obj.data;
        columns: columns,
      dataadapter = new $.jqx.dataAdapter(source, {
          console.error(error);
        beforeSend(jqXHR, settings) {
          if (window.lastGridUrl)
            lastGridUrl = settings.url;
    $(document).ready(function(){
                _grid = $("#jqxgrid");
                _grid.jqxGrid(gridOptions);
                _grid.jqxGrid('localizestrings', jqxGridLocalizationObj);
                _grid.jqxGrid('source', dataadapter);
            function applyFilter(){
                var filter_and_operator = 0;
                var hasFilter = false;
                var date = dateFromHidden.val().trim();
                if(date && date.length){
                    var filter = filtergroup.createfilter('datefilter', date, 'GREATER_THAN_OR_EQUAL');
                    filtergroup.addfilter(filter_and_operator, filter);
                    hasFilter = true;
                date = dateToHidden.val().trim();
                    var filter = filtergroup.createfilter('datefilter', date, 'LESS_THAN_OR_EQUAL');
                    hasFilter = true;
                if(hasFilter){
                    _grid.jqxGrid('addfilter', 'RequestDate', filtergroup);
                    _grid.jqxGrid('applyfilters');
                    removeFilterBtn.show();
    My initial grid load 3 rows from server.
    When applyFilter() is called the data is filtered correctly from the server and returns 1 row of data.
    The grid showing that 1 row BUT also there is still 2 empty rows in the grid. How can i get rid of those empty rows?
    Exlord
    Anyone?
    I just noticed the the pager is not getting updated either, it still thinks that the grid has the full set of the rows!!!
    Exlord
    Wooooops sorry the problem was on my server side filtering, I was getting the total row count before applying the filters :D, that was messing up the pager …,
    But this is still a bug, if my data contains only 1 row after filtering the grid should NOT create extra empty rows just because totalRowsCount says so!
    Hello Exlord,
    I would like to suggest you look at this demo:
    https://www.jqwidgets.com/jquery-widgets-demo/demos/php/serverfiltering_paging_and_sorting.htm?light
    (if everything is correctly set, it cannot produce such issue – with empty rows)
