jQuery UI Widgets Forums Getting Started aggregates does not work after ‘clear’ and ‘addRow’
This topic contains 6 replies, has 3 voices, and was last updated by  Peter Stoev 11 years ago.
  • jahnvi25
    i have gird displaying aggregates just fine.. but after following code
    $(‘#jqxGrid’).jqxGrid(‘clear’);
    $(‘#jqxGrid’).jqxGrid(‘addrow’, null, newRows);
    it shows statusbar.. but no aggregates on that one.. how can i force to re-calculate and load the aggregates.. ?
    Hi jahnvi25,
    Could you please post a more complete sample?
    In general, “refreshaggregates” updates the aggregates.
    $('#jqxGrid').jqxGrid('refreshaggregates');
    If you want to completely re-render the aggregates, use “renderaggregates”.
    $('#jqxGrid').jqxGrid('renderaggregates');
    jahnvi25
    here is the example.. click on “load new data”.
    <link rel="stylesheet" href="assets/jqwidgets/styles/jqx.base.css" type="text/css" />
    <script type="text/javascript" src="assets/js/jquery-1.10.2.min.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxcore.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxdata.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxbuttons.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxscrollbar.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxmenu.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxgrid.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxgrid.selection.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxgrid.grouping.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxgrid.edit.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxgrid.filter.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxgrid.columnsreorder.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxlistbox.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxdropdownlist.js"></script>
    <script type="text/javascript" src="assets/jqwidgets/jqxgrid.aggregates.js"></script>
    var tempData = new Array();
    var data = new Object();
    data.id = "row1";
    data.header = "Angel";
    data.action = "Buy";
    data.price = 2.3;
    tempData.push(data);
    //second row
    data.id="row2";
    data.header = "Miriam";
    data.action = "Sell";
    data.price = 4.5;
    //var data = [{ id: "row1", firstname: "Angel", lastname: "Bradley" }, { id: "row2", firstname: "Miriam", lastname: "Roche"}];
    datatype: "array",//"json",
    localdata:tempData,
    {name: 'header', type: 'string'},
    {name: 'action', type: 'string'},
    {name : 'price',type:'number'}
    var columns = [
    {text:'Header',datafield:'header',hidden:false,editable:false,sortable:false},
    {text:'Action',datafield:'action',hidden:false,editable:true,sortable:false},
    {text:'Price',datafield:'price',hidden:false,editable:true,sortable:false,
    aggregates: [{'Net ':
    function (aggregatedValue, currentValue, column, record) {
    var total;
    if(record['action'] == 'Buy')
    total = currentValue * 1;
    else if(record['action'] == 'Sell')
    total = currentValue * (-1);
    return aggregatedValue + total;
    }],aggregatesrenderer:function (aggregates, column, element) {
    var renderstring = "<div class='jqx-widget-content jqx-widget-content-basic" + "' style='float: left; width: 100%; height: 100%; '>";
    $.each(aggregates, function (key, value) {
    var val = value;
    if(val)
    val = (val * 1).toFixed(2);
    renderstring += '<div style="position: relative; text-align: right; overflow: hidden;">' + key + ': ' + val + '</div>';
    renderstring += "</div>";
    return renderstring;
    $("#jqxgrid").jqxGrid(
    width: 400,
    sortable: false,
    columns: columns,
    editable: false,
    filterable:true,
    showaggregates: true,
    showstatusbar: true,
    statusbarheight: 20,
    altrows: true
    //groupable: true
    $('#jqxgrid').on('cellendedit', function (event) {
    var args = event.args;
    var row = args.rowindex;
    var id = $('#jqxgrid').jqxGrid('getrowid', row);
    alert(id);
    $("#BtnDiv").on('click','#btnSnap2',function(){
    var rows = $('#jqxgrid').jqxGrid('getrows');
    $('#jqxgrid').jqxGrid('clear');
    $('#jqxgrid').jqxGrid('addrow', null, rows);
    <div id="jqxgrid">
    <div id="BtnDiv">
    <input type="button" id="btnSnap2" value="load new Data">
    jahnvi25
    even if you generate new data like below.. still does not work
    //var rows = $('#jqxgrid').jqxGrid('getrows');
    data.id = "row1";
    data.header = "new name";
    data.price = 2.67;
    $('#jqxgrid').jqxGrid('addrow', null, tempData);
    jahnvi25
    anything ? how can i fix this ?
    lleveille
    Same issue … aggregates do not work when I have an empty grid and I add rows using ‘addRow’.
    Once I save and the grid has atleast one row to start with the aggregates start working.
    Hi lleveille,
    Aggregates would not be recalculated automatically if you add/remove row. That is why there’s a method in jqxGrid which is called $(‘#jqxgrid’).jqxGrid(‘refreshaggregates’);
