jQuery UI Widgets › Forums › Scheduler › addAppointment not using given id
This topic contains 4 replies, has 2 voices, and was last updated by svetoslav_borislavov 2 years, 3 months ago.
I’m trying to add a placeholder appointment with a specific id that I can manipulate/delete later, but I’m finding that the appointment is created with everything except the id. It’s being created with a generated id like 3120-26-20-18-21. I’m also pulling in an external data source for appointments and the ids work fine from that. Any help is appreciated.
here’s my data fields
appointmentDataFields: { from: "start", to: "end", id: "id", description: "description", subject: "subject", draggable: "draggable", resizable: "resizable", },
here’s the code adding the appointment
//add placeholder appointment let placeholder_appointment = { id: "new", description: 'new', subject: 'new', start: start_date, end: end_date, draggable: false, resizable: false, }; dest_schedule.jqxScheduler('addAppointment', placeholder_appointment);
here’s the source
dest_schedule_source = { datatype: 'json', datafields: [ { name: 'id', type: 'string' }, { name: 'description', type: 'string' }, { name: 'subject', type: 'string' }, { name: 'start', type: 'date' }, { name: 'end', type: 'date' }, ], id: 'id', };
The only way to do this is to set the dataSource with the new appointment added.
If you use the ‘addAppointment’ method the scheduler will generate ids, so just set new dataSourceI hope this helps!
Svetoslav BorislavovjQWidgets Team
https://www.jqwidgets.com/Ok, I’ve built the placeholder into the my data source and it gets get created with the correct id. Now I’m trying to update the to and from dates for the appointment. However, when I try to update the appointment date it disappears. I’ve verified through logging that the appointment still exists and has the correct date, but is no longer visible.
The appointment is created with
from: Thu Jan 12 2023 06:00:00 GMT-0600 (Central Standard Time)
to: Thu Jan 12 2023 06:30:00 GMT-0600 (Central Standard Time)And I’m using this code to change it
let start_date = new Date("2023-01-12 06:30:00"); let end_date = new Date("2023-01-12 07:00:00"); //update placeholder appointment dest_schedule.jqxScheduler('beginAppointmentsUpdate'); dest_schedule.jqxScheduler('setAppointmentProperty', 'new', 'from', start_date); dest_schedule.jqxScheduler('setAppointmentProperty', 'new', 'to', end_date); dest_schedule.jqxScheduler('endAppointmentsUpdate'); console.log(dest_schedule.jqxScheduler('getAppointmentProperty', 'new', 'from')); console.log(dest_schedule.jqxScheduler('getAppointmentProperty', 'new', 'to'));
The logging shows that the dates have changes, but the appointment is gone from the scheduler.
If I try to call ensureAppointmentVisible after the above code, it crashes the page.
Nevermind, I needed to convert the dates to jqx date objects. Works for me now.
let jqx_start_date = new $.jqx.date(start_date); let jqx_end_date = new $.jqx.date(end_date);
Thank you for the feedback!
If you have any additional questions, do not hesitate to contact us!Best regards,
https://www.jqwidgets.com/ -
