jQuery UI Widgets Forums Grid add row with dropdown in grid and retrieve values through ajax call
This topic contains 4 replies, has 2 voices, and was last updated by  Dimitar 10 years, 10 months ago.
  • Nagoor
    hi,
    using your example (http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/cascadingediting.htm?arctic ) , i implemented dropdown in grid. but in your example you are giving the values for cities directly,but i need to bring them from server and also i need to have city code and city label in which i need to display label in drop down and on selecting i need to get city code. my problem is..
    1. i can able to send data through ajax call, but i couldn’t able to return value from the controller. i am using SpringMVC architecture.
    hre is the sample
    ///// jsp call
    jQuery.ajax({
    type : ‘POST’,
    data : ‘serviceIdAdd=’+service,
    url : ‘ServiceToAddsWellRequest’,
    success : function(data, textStatus) {
    alert(“success”);
    alert (“data recieved from server “+data);
    error : function(XMLHttpRequest, textStatus, errorThrown) {
    alert(“errorThrown “+errorThrown);
    ////// in controller
    @RequestMapping(value = “/ServiceToAddsWellRequest” , method = RequestMethod.POST )
    public String ServiceToAddsWellRequest(HttpServletRequest request) {
    String sid = request.getParameter(“serviceIdAdd”);
    System.out.println(“Service Id recieved “+sid);
    Gson gson = new Gson();
    ServiceEditDetailsRequestFormbean serBean = requestFormDAOImpl.ServiceInfo(sid);
    String data = gson.toJson(serBean);
    System.out.println(“data to send “+data);
    return data;
    2. i have a button add row in the page. onclick of button i need to add another row to the grid with same type of data ie., new country with its code i one coloumn and its respective states (as a dropdown) with codes in next coloumn.
    pls help me ASAP..
    Thanks in Advance
    Nagoor
    Nagoor
    hi,
    I found the solution to return from ajax call. pls help me adding the rows to grid as i specified..
    Thanks in Advance
    Nagoor
    Hello Nagoor,
    Please check out the following modification of the demo Cascading ComboBoxes. We hope it is helpful to you.
                var data = '[{ "Country": "Belgium", "City": "Brussels"}, {"Country": "France", "City": "Paris"}, {"Country": "USA", "City": "Washington"}]';
                        { name: 'Country', type: 'string' },
                        { name: 'City', type: 'string' }
                    localdata: data
                var countriesAndCities = [{ Country: "Belgium", Cities: ["Bruges", "Brussels", "Ghent"] }, { Country: "France", Cities: ["Bordeaux", "Lille", "Paris"] }, { Country: "USA", Cities: ["Los Angeles", "Minneapolis", "Washington"]}];
                $("#jqxgrid").jqxGrid(
                    width: 300,
                    selectionmode: 'singlecell',
                            text: 'Country', datafield: 'Country', width: 150, columntype: 'combobox',
                            cellvaluechanging: function (row, datafield, columntype, oldvalue, newvalue) {
                                if (newvalue != oldvalue) {
                                    $("#jqxgrid").jqxGrid('setcellvalue', row, "City", "Select a city...");
                            text: 'City', datafield: 'City', width: 150, columntype: 'combobox',
                            initeditor: function (row, cellvalue, editor, celltext, cellwidth, cellheight) {
                                var country = $('#jqxgrid').jqxGrid('getcellvalue', row, "Country");
                                var city = editor.val();
                                var cities = new Array();
                                for (var i = 0; i < countriesAndCities.length; i++) {
                                    if (country == countriesAndCities[i].Country) {
                                        cities = countriesAndCities[i].Cities;
                                        break;
                                editor.jqxComboBox({ autoDropDownHeight: true, source: cities });
                                if (city != "Select a city...") {
                                    var index = cities.indexOf(city);
                                    editor.jqxComboBox('selectIndex', index);
                $("#newRow").click(function () {
                    countriesAndCities.push({ Country: "Bulgaria", Cities: ["Sofia", "Troyan", "Varna"] });
                    $("#jqxgrid").jqxGrid("addrow", null, { Country: "Bulgaria", City: "Troyan" });
        <div id="jqxgrid">
        <button id="addNewRow">
            Add new row</button>
    Nagoor
    Hi Dimitar,
    Thank you for this example, it works perfectly in my case. i just need to know one more thing. how to make the combobox ineditable ie., one can just select from dropdown but could not edit the value in cell. pls help me with this
    Thanks & Regards
    Nagoor
    Hi Nagoor,
    We suggest you use a dropdownlist editor instead. You can see the two types of editors in action in the demo Customized Editors. In the above example, this would mean changing 'combobox' to 'dropdownlist' and editor.jqxComboBox to editor.jqxDropDownList.
